Can I run the engine long enough to turn the car around without the Upstream O² Sensor operating once I cut the burnt wires running to it?
360,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
SANDSTORM58
  • 16 POSTS
The idiot mechanic who last worked on my car changing that manifold didn't reconnect the harness in the proper place allowing it to fall into a gap in the manifold melting the connector and shorting out the system. It blew 4 20A Engine Fuses before finding it after placing a new PCM in the car.
Jul 14, 2022 at 12:08 PM
  • 110,244 POSTS
Absolutely, you can. It will likely set a code, but chances are that has already happened if the wiring was melted.
Let me know if you run into any trouble or have questions.
Jul 14, 2022 at 3:17 PM
SANDSTORM58
  • 16 POSTS
Code probably didn't set since I was attempting to check injector signals with a NOID light, and it never fired. Not worried about the code as I can clear it. Will let you know if I need help with it after I get it changed.
Jul 14, 2022 at 3:24 PM
  • 110,244 POSTS
You are very welcome. Let me know how things turn out for you. If you need schematics for the injection circuit, let me know.
Jul 15, 2022 at 2:19 PM
