Blown out 2 blower resistors
199,800 MILES • 3.2L • V6 • 2WD • AUTOMATIC
DUDEROCK
  • 11 POSTS
Blown out 2 blower resistors. The main screen on the center console don't work. Pushing the auto and off buttons I get err E1, so where do I go? blown 2 resistors. Replaced wiring from resistor to blower, only code is E1.
Apr 9, 2021 at 8:38 AM
Good evening,
The blower motor should be replaced. It sounds like it is drawing too much current and it overheating and failing the resistor.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
I attached a wiring diagram for you.
Apr 9, 2021 at 8:53 AM
DUDEROCK
  • 11 POSTS
The blower motor is pulling 7 amps running 8.5 starting.
Apr 9, 2021 at 9:33 AM
Okay, how is it working with failed resistors?
What speed is that measurement from?
Apr 9, 2021 at 9:42 AM
DUDEROCK
  • 11 POSTS
With engine running out amp meter on wires to motor as soon as you turn on automatic the blower starts. That's when I get my reading and there is no speed control on automatic. If you bypass the resistor briefly you can check motor and wiring.
Apr 9, 2021 at 10:09 AM
I would still replace the blower and the resistor together.
Apr 9, 2021 at 10:11 AM
DUDEROCK
  • 11 POSTS
Okay, I'll get another blower.
Apr 9, 2021 at 10:15 AM
Keep us updated.
Apr 9, 2021 at 10:18 AM
DUDEROCK
  • 11 POSTS
I will. they had to order it at over $70.00 with no wheel.
Apr 9, 2021 at 10:22 AM
That is a bad price. I attached the parts from Rock Auto for you.
Apr 9, 2021 at 10:27 AM
DUDEROCK
  • 11 POSTS
Got the motor installed it gave the car to customer and told her to cross her fingers. If any more trouble I will be back.
Apr 10, 2021 at 11:13 AM
Did you replace the resistor with it as well?
Apr 10, 2021 at 12:30 PM
DUDEROCK
  • 11 POSTS
Yes, at a cost of $116.00 plus my time.
Apr 10, 2021 at 3:41 PM
