Hi Chrissy,
It will fit in but it is not plug and play. You are taking an engine out of an LH body style and putting it into an LX body. The actual body of the vehicle is not the biggest deal. It is the electrical architecture as they are different. This means the newer vehicle uses many more modules and sensors then the older vehicle did.
Are they both 3.5 L engine vehicles originally?
If the transmission is the same in both meaning they would need to both be 42LE transmissions, then it should fit and bolt to the transmission.
However, you will need to retro fit all of the engine sensors that the 2008 PCM is looking for that the older engine does not have.
I have never done this so I am not sure everything you will need to look for but just be prepared to spend a lot of time rewiring the wiring harness to fit the older engine. You will not be able to transfer any of the modules over because they are not compatible so you will have to figure out ways to basically trick the systems in the newer vehicle to allow it to start the engine.
In my opinion, it would be fun to try but I think you are going to run into incompatibility issue that will not allow the PCM to start the engine. Basically, because it will be looking for things that the older engine just doesn't have so you will have connectors that are left off or worse yet, the sensors from the older engine won't even plug into the older style connectors.
Sorry I don't have better news, but I would not try this. If you can find an engine from the same body style, LX, then you shouldn't have near the problems that this will encounter.
Let me know if I can help in any other way.
May 28, 2019 at 7:54 AM
