Blown head gasket
147,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
PAULAZNYOUNGAZ
  • 10 POSTS
Was wondering where i might be able to get detailed repair instructions that are easy to follow so i can repair blown head gasket myself?
Thank you. Your help would be much appreciated.
Sep 9, 2017 at 7:32 PM
  • 55,550 POSTS
Start by disconnecting the battery and draining the coolant.
Here are a couple of guides to help you get started:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
and
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
and
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Start by removing the intake manifold.
https://www.2carpros.com/articles/replace-intake-manifold-gasket
and then the exhaust manifolds and valve covers.
https://www.2carpros.com/articles/replace-valve-cover-gasket
Here is a gasket set from Amazon for $70.00 and it has head bolts:
https://www.amazon.com/gp/product/B007P722QQ/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B007P722QQ&linkId=5467da101bc7cb146e490a8269378f2d
Here are some diagrams to help you see what it will be like on your car (below):
Tighten the new cylinder head bolts to 60 Nm (44 lb ft) in the order shown. Use the J 36660-A torque angle meter in order to rotate the cylinder head bolts an additional 95 degrees.
Change the oil when you are done.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Please let us know what happens and upload pictures of the problem.
Cheers, Ken
Sep 11, 2017 at 5:12 AM
