Blown head gasket coolant and oil mixed engine
156,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
JOHN CLUTCH CARROLL
  • 8 POSTS
I had chocolate milk looking oil while driving the car, it now dies on me. earlier it died and went to go start it back up and made some clunking noises and was bubbling chocolate milk from the valve cover gaskets. the engine still turns over fine but I am afraid to run it. I am going to do the head gasket job, but want to know if there is any kind of way to clean the bottom and good enough to save it without replacing anything or can I replace the rod and main bearings without breaking it down by just taking off the oil pan and loosening the main caps?
Sep 6, 2016 at 3:42 PM
HMAC300
  • 48,601 POSTS
when head gsket is replaced drain all oil then replace it and filter, clean all parts as well. then run engine and change oil again after a few minutes.
Sep 6, 2016 at 11:55 PM
JOHN CLUTCH CARROLL
  • 8 POSTS
Thanks man I hope all is good with it when I'm done..........
Sep 10, 2016 at 12:47 PM
JOHN CLUTCH CARROLL
  • 8 POSTS
Got any other advice on the oil sending unit and turbo and turbo line that I should do?
Sep 10, 2016 at 12:48 PM
HMAC300
  • 48,601 POSTS
your image didn't show up or just part of it did. if you have have a turbo make sure oil lines are not leaking and use reinforced one for pressure that is the type that has steel braid around it. if sending unit leaks then just replace it . also after all the milky stuff is out of oil switch to synthetic oil especially with a turbo.
Sep 11, 2016 at 1:03 AM
JOHN CLUTCH CARROLL
  • 8 POSTS
Thanks man I really appreciate it......one last question.......what turbo can I use to upgrade I got the .52 bigger 16g.......and a arm boost solenoid.........hooked up
Sep 11, 2016 at 1:22 PM
JOHN CLUTCH CARROLL
  • 8 POSTS
Aem*
Sep 11, 2016 at 5:26 PM
HMAC300
  • 48,601 POSTS
no idea on that one as I dont' mess around with stuff like that try banks turbo they are online they may know
Sep 11, 2016 at 11:23 PM
