Possible blown head gasket?
1999 CHEVROLET 3500
140,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
UDM1989
I'm pretty sure I have at least blown my head gasket, if not worse. I was pushing my engine pretty hard going 80 MPH uphill when the engine quit. I placed it in neutral and tried the restart the engine. The starter would crank, so I coasted to a stop. Lifted the hood and found milky oil all over the passenger side of the engine. It seems to have blown out of the dipstick tube. I check the radiator and it was significantly low as I expected due to the milky oil. I am guessing head gasket failed which allowed coolant into the crankcase and blowing the oil/coolant mixture to spray out of the dipstick tube. I am planning on replacing the head gaskets but wanted to see if I might be missing something in my diagnosis. How likely am I right and am I missing something else which could have happened?
Oct 18, 2021 at 5:19 AM
Good afternoon,
Sounds like you are correct. The fact that the oil is milky tells me you need main and rod bearings as well. Once coolant hits the bearings, it damages the babbitt on the bearing and they must be replaced.
https://www.youtube.com/watch?v=8es2qK6MA_E
I attached a YouTube from our company on rebuilding the motor which is what you will be doing.
Let me know if you have any other questions.
Oct 18, 2021 at 5:50 AM
UDM1989
Hi Roy,
Thank you for the quick response! You mentioned replacing the bearings due to the coolant. I am really hoping to just replace the head gaskets. With the engine stalling
when this happened, do you still believe the bearing need to be replaced? I know you are correct that replacing the bearings would be best, but how big a risk do I run with not replacing the bearings?
Thanks,
Eric
Oct 18, 2021 at 6:09 AM
It is a very high risk. The engine oil pressure will drop and start to knock and by then you have crank damage and more damage.
It could last for weeks or less.
Oct 18, 2021 at 6:11 AM
