Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
General
Fuse Test
Blown gauge fuse
1997 TOYOTA CAMRY
118,967 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
MYRON MCMILLAN
MEMBER
1 POST
Why does my gauge fuse blow every time I crank the car? I replaced the engine wire harness.
Jul 30, 2016 at 1:34 PM
HMAC300
Experienced Mechanic
it cold be the wrong harness you replaced and not for your exact model car and something is causing it to blow the fuse because it is shorting out.
Jul 31, 2016 at 1:30 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
