Blown Fuse
132,234 MILES • 3.2L • V6 • FWD • AUTOMATIC
BIGLYNCH
I just replace a new brake light switch, bulbs, fuse and brake light connectors. Soon as I pressed the brakes they blow the fuses right away. It also did the same thing with the old brake light switch before I replaced it. The fuse amp for the brake light is 15A, but I have two fuse boxes in the rear seat of my Cadillac on both sides. Only one shows the fuse 15A for the BAS on the left fuse box, but the right fuse box does not have it. I need to know how to get my brake light working again and what causing the fuse to blow soon I press the brake pedal. Also, there is a black amplifier box on the left in the trunk connect to the circuit and on the right side is a small silver box connected to the circuit.
Mar 13, 2016 at 4:35 AM
HMAC300
  • 48,601 POSTS
there is a short in wiring causing this. If the car was in a recent accident the wiring was could have been damaged and not fixed, you'll either have to have a pro do it or trace all your wiring to the back from front.
Mar 13, 2016 at 7:17 AM
