ECU fuse keeps blowing
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
JERRY HOWSER
My car keeps blowing the ECU fuse. What could be the problem?
Aug 18, 2019 at 9:12 PM
Good morning,
You would need to disconnect the module and see if the fuse still fails. If it does, it is a wiring harness issue.
If it does not, then it is an internal issue with the module.
Component Locations-Behind RH Side Of I/P (VIN 4 Shown, VIN T Similar)
Aug 18, 2019 at 9:55 PM
