Blowing sound from intake valves
100,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
MLUNGISI
  • 8 POSTS
I recently did a top-end overhaul on a Nissan YD25 engine, Tested the vehicle for 190 km. then later heard a blowing sound from the inlet valve.
I removed the cylinder head and I noticed that the one inlet valve was partially closed and was running tight, took it to the engineers to confirm. they repaired the cylinder head. After fitting it the same problem recurred after driving for 40 km.
What could be the cause?
Mar 4, 2022 at 12:50 AM
Just to be clear you have valves hanging open after running the engine?
If this is the case, then the cause of a sticking valve is normally heat but this would take longer than a few miles. So, what it sounds like is the valve guides are too tight and it is causing the valves to stick and hang open.
You can confirm this is happening again by running a compression check before you remove the head again. Here is a guide that will help with this:
So more than likely the valve guides are the issue, or the head is damaged in ways that I am not sure yet.
What is the history of this vehicle? Why did you originally do the top end overhaul? Did you have an issue prior to this, and did you replace the guides?
Let's start with this info and go from there.
Thanks
Mar 5, 2022 at 9:35 AM
MLUNGISI
  • 8 POSTS
The reason for doing the top-end was after one overhead cam broke, resulting in a bent valve, the engineers say they have replaced all the valves and buckets. I inspected my bottom half, and all seems fine except for the head, it only happens after running when the engine has reached optimum temperatures.
Mar 5, 2022 at 4:54 PM
Check the guides as well. They may be causing the valve not to seat when it gets hot.
Mar 5, 2022 at 6:28 PM
MLUNGISI
  • 8 POSTS
Sure, thanks. will check and update.
Mar 5, 2022 at 6:52 PM
Please keep us updated.
Mar 5, 2022 at 6:55 PM
MLUNGISI
  • 8 POSTS
Thanks so much for the assistance the problem has been resolved.
Mar 14, 2022 at 5:16 PM
MLUNGISI
  • 8 POSTS
I have another problem developing from another YD25 engine. When driving it's having intermittent power loss. have replaced the prime pump, sediment sensor cleaned the fuel tank, and put new diesel filter, still, I am having the same problem.
when driving the vehicle just loses power.
Mar 14, 2022 at 5:24 PM
Site rules are one subject per question.
Please start a new question and we will be glad to help you.
Mar 14, 2022 at 6:32 PM
