Blowing oil
170,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
BALLINBURNETT
I am blowing oil everywhere. It started by blowing my dipstick out and so I zip tied it down and now everything under my hood is soaked in oil. I replaced the PVC valve and spark plugs and nothing has helped. I do not blow smoke out my exhaust and there is no knocking. Just blowing oil everywhere.
Jun 11, 2017 at 6:39 AM
FREEMBA
  • 1,152 POSTS
Start the engine and remove the PCV valve from the valve cover (with the hose attached). Place your finger over the end of the PCV valve to see if it have strong suction. If so it is operating properly. If not, stop the engine and clean the hose and intake port where the PCV connects.(they sometimes become clogged).Also, make sure that the hose that runs from the air cleaner to the valve cover is not clogged. Let me know the results. Thanks.
Jun 11, 2017 at 8:29 AM
