Fuses number one and seven in the interior fuse box keeps blowing
1997 JEEP GRAND CHEROKEE
190,889 MILES • 5.2L • V8 • 2WD • AUTOMATIC
D1OUTLAW
in the interior fuse box fuses number one and seven keeps blowing. Number one is for the radio. (10 amp) and number seven is for the instrument cluster (20 amp).
Oct 2, 2016 at 6:22 AM
HMAC300
  • 48,601 POSTS
Number one goes directly to radio so check red wire to see if something has been attached to it like an aftermarket alarm system. if it has disconnect that and see if it continues if it does then check for a grounded wire or shorted. same for number seven as it is a violet wire. then disconnect the cluster and see if it still blows if it does then have it scanned for codes as it may be a BUS problem or a bad module as that one powers three different ones.
Oct 2, 2016 at 9:03 AM
