Blowing fuses
ALL OTHER MAKES ALL OTHER MODELS
PHANTOM11
Car was not used much, let battery run down, plus needed new one. Installed new battery, ran every once in awhile to keep battery charged and always ran radio, A/C, seats, mirrors, windows,
exterior lights ect. to make sure they worked, let battery run down and recharged it, started vehicle, ran fine, but A/C, windows, info/msg center, wipers and interior dome lights did not work.
Checked inside fuse panel and found the following fuse's blown, the following is taken from the owners guide. #25 a 7.5A Generic Electronic Module (GEM), Instrument Cluster, Securi-Lock,
#34 a 7.5A Rear Integrated Control Panel, CD and #36 a 7.5A EATC Memory,CD,Rear Integrated Control Panel, memory Seat, Message Center and a 10A fude in the Power Distribution
Box #5 Air Bag Diagnostic monitor. Replaced the fuses and they blew again, same three.removed battery ground and replaced 10A, soon as I touched the ground wire to battery the 10A blew.
I pulled the GEM out and had read if the fuse didn't blow with it out then the GEM was bad (don't know about that, I am not a mechanic), anyways tried it, but the 10A blew again, that's the only fuse I tried. Have had a problem with the light/clock function on the radio, usually not lit, but every once in a while they come on, like there is a short there, never interfered with any thing else
working, and I have the Eddie Bauer, it has a removable 6 dicd cd player, that quit working quite a while ago, but cd player worked ok. Looking at the GEM, it looks OK to me, no rust or corrosion, is there a way to check it out to make sure its good. Only thing I ever did electrically to vehicle was disconnect the drivers side power window from the armrest control, the window came out of the track and try as I might I could not get it to stay in the track inside the door, everytime I got it back in, my wife would forget and I would have to pull the panels and get it back in, so I disconnected, still before recharging the battery, all worked fine. Any ideas on the cause and a cure. Some of the stuff I have read said to trace the wires out looking for frayed, cut ect.
Can't see how to do that when the majority of them are not visable. Don't really know what to do.
Apr 14, 2013 at 1:37 AM
HMAC300
  • 48,601 POSTS
what kind and year of vehicle?
Apr 14, 2013 at 2:57 AM
PHANTOM11
1998 Ford Explorer Eddie Bauer 4x4 4.0lEngine with 122,000 miles.
Apr 15, 2013 at 5:13 AM
PHANTOM11
Pulled fuse box or got it out as far as I could, did not look like anything burnt or cut, ect. When I turned ignition on (not start) I noticiced static like noise coming from drivers door speaker, since I had panel off, I pulled speaker, then noticed same noise from passenger door speaker.. Don't understand why there is noise with radio off? All gauges in instrument cluster work and engine lights, ABS, Check Engine, Air Bag ect. come on when ignition is turned to on. Lights in overhead panel do not work altho Temp and Compass light up and changes to metric when chosen.
Overhead lights in read do not work either.
Bud
Apr 15, 2013 at 5:26 AM
HMAC300
  • 48,601 POSTS
you will pretty much have to do what it said look for inched, bare wires to find out why fuse is blowing. if it doesn't itright away then there is a serious problem.try disconnecting your cd as two of those lead ot that, the gem module needs to be scanned to see if it's good you can't just look at it so it needs power. the static may be coming form cd.
Apr 15, 2013 at 5:32 AM
HMAC300
  • 48,601 POSTS
one other thing you may have to have a mechanic look at this as this one is very hard to do over the computer you cold try a compass for the short, when it hits the short it will go crazy.also check that disconnected wire to window that may be your problem as well.
Apr 15, 2013 at 5:39 AM
PHANTOM11
Will a bad GEM cause fuses to blow. Window wire is okay, still have door panel off, taped end of wire and it is not touching anything.
Apr 15, 2013 at 10:27 PM
HMAC300
  • 48,601 POSTS
you have to many fusses going at once and the GEM should be tested anyhow if they are not blowing with GEM disconnected i'd say maybe but there are other tings that the gem hooks to that could be bad as well.
Apr 15, 2013 at 10:55 PM
