It’s about 7 degrees here. I had not started my truck in about a week prior to this. I started my truck and let it run for about 15 minutes then drove it around. It was a little hesitant to start but started. Heat worked. Everything was all good. I left the heat and radio settings in the on positions when I turned the truck off for the night. I didn’t leave a dome light on the doors were all shut. There wasn’t anything running the battery down that I know of. The next day tried to start the truck and there was no power. Dash and dome lights came on. Click click. Left it alone and didn’t charge it. I did turn the heat and radio off before taking he key out of the ignition. This morning, a day later, first try, the truck started right up. Drove it to and from work with no starting issues. Halfway to work I’m still freezing. The air is cold from the vents. Blows great. If I have it on the front windshield setting the air feels barely warm. It blows real cold air if it’s sat on any other setting. I figured the air was a little warm blowing from the windshield setting because of the heat off the engine. I drove it almost half the day and it never warmed up. Temperature gauge stays below the half mark. I don’t know if all this is correlated or not. Has anyone heard of anything like this? Where do I start looking for the problem?
Feb 18, 2021 at 8:30 AM
