blower will not turn off on air conditioner
107,000 MILES • 5.6L • V8 • 4WD • AUTOMATIC
GRNEYEZ78
when I turn the power off to the air cond. the blower will not shut off its stuck on high
Sep 24, 2014 at 5:44 AM
HMAC300
  • 48,601 POSTS
if it happens all the time then check your blower relay under right side of dash. if it happens intermittently then there is a ts b on it and you need to replace a fin on heater switch part number 27151-zw00a see pic
Sep 24, 2014 at 10:52 PM
GRNEYEZ78
Thanks..you are exactly right..it was the part number you said..thanks
Sep 25, 2014 at 6:23 AM
