Blower resistor location
15,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
RICH DEGROOT
The fan speed only works on number 4. I want to know where the resistor is located. It has manual control. I saw an image of the resistor but do not know where it is located. Vehicle listed above is an S model.
Jan 11, 2020 at 6:59 AM
BMDOUBLE
  • 1,139 POSTS
It is mounted on the driver side of the plenum so you'll need to remove the accelerator pedal. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jan 11, 2020 at 8:08 AM
PEDEVILLE
Where is the fan motor blower resistor block on my model vehicle, I looked in the vent areas of the dash
Oct 5, 2020 at 4:38 AM (Merged)
CARADIODOC
  • 34,414 POSTS
Do you have manual or automatic heater controls? If you have manual controls, look for a four-wire connector plugged into an assembly held in with four screws. If you have an automatic, computer-controlled heater system, Ford's engineers have gone insane with inappropriate use of technology and you will have a computer module that controls fan speed through pulse-width modulation. As with a lot of this delicate electronics, the perceived "convenience" is far over-shadowed by the uncommonly high cost of diagnosis and repair. I hope you have the simpler system.
PEDEVILLE
But where location wise do I look for this four wire harness specifically?
CARADIODOC
  • 34,414 POSTS
Sorry that I overlooked that. It's top secret and I can't tell you! Actually, I don't know exactly where it is, but the heat sink on it has to be air-cooled by the air getting blown through the heater box. You're going to find this assembly on the top or side of the heater box under the right side of the dash. It is bolted on where you can get to it to replace it, but on some cars that is done by removing the glove box.
If you have a computer-controlled system, you typically won't have a resistor assembly. With a resistor assembly, you're going to have three or four fan speed choices. If you can vary the fan speed anywhere between low and high by turning a dial or pressing "up" and "down" buttons, that has a computer involved that uses pulse-width modulation. No resistor is used with that system. This is what I was referring to where you get the convenience of the variable speed fan at the cost of a huge repair bill.
2CP-ARCHIVES
  • 4,540 POSTS
My heat and A/C will only work on level 4, and I think that it is the blower motor resistor. Where is it located so I can replace it?
DRCRANKNWRENCH
  • 3,380 POSTS
It is on the right side of the dash. See attached.
I am attaching the instructions on how to replace this in the event that you are not able to find it. This will show what needs to be removed to access it. Let us know what else you need or how you make out. Thanks
Oct 5, 2020 at 8:08 AM
