blower resistor wiring black wire gets hot and melts?
132,633 MILES • 4.3L • V6 • 2WD • AUTOMATIC
COMPUSATLLC
blower resistor.
Aug 10, 2023 at 1:15 AM
  • 110,251 POSTS
The black wire is the ground. If it is getting hot and melting, either we have a faulty blower motor (drawing too many amps) or a poor connection.
Inspect the connector to make sure the pin isn't corroded, damaged, or pushed in preventing a good connection. (See pic below) Also note that if you have already replaced the wire and it was done with a lighter gauge wire, which will cause this as well.
If that is good, locate the ground (G200) near the A-pillar. That is the left side pillar where the windshield is mounted. See pic 2. Note the location is high in the dash.
Aug 10, 2023 at 1:06 PM
COMPUSATLLC
my wiring is not like that.
Aug 12, 2023 at 7:42 AM
  • 110,251 POSTS
That is what my manual is showing for an 06 1500. What is different? Let me know and I'll dig through some other schematics to see if I can match it.
Aug 12, 2023 at 1:24 PM
