Blower motor works then slows down and stops?
12,100 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
PORK CHOP
  • 5 POSTS
Blower motor works for a few minutes and stops working it has automatic climate control.
Nov 1, 2024 at 1:39 PM
  • 110,248 POSTS
When this happens, can you get it to turn on by adjusting the temperature to a point when it should be running? Does the blower motor make any odd sounds?
Nov 1, 2024 at 3:13 PM
PORK CHOP
  • 5 POSTS
No, the blower motor goes from fast and slows down and stops turning the heat up doesn't work.
Nov 1, 2024 at 4:39 PM
PORK CHOP
  • 5 POSTS
A little squeak just at stop.
Nov 1, 2024 at 4:41 PM
  • 110,248 POSTS
There is a chance the blower motor is failing. The squeal you hear could be related to the motor itself.
What we need to do is check to see if it continues to get power once it stops running. At the blower motor, there will be two wires. One is blue with a brown tracer. That functions as the ground for the motor.
The power supply wire color isn't indicated on the schematic. See pic below. When the fan should be running, I need you to check if that wire has power. You can use a test light or voltmeter. If the motor is getting power, chances are it is faulty.
Let me know if that is something you are comfortable performing.
See pic below.
Nov 2, 2024 at 2:51 PM
PORK CHOP
  • 5 POSTS
Tested it and motor is no good.
Nov 2, 2024 at 5:32 PM
  • 55,658 POSTS
Good job, here is a test you could have used to test it and the correct way to replace the blower motor.
https://www.2carpros.com/articles/how-to-test-an-automotive-hvac-system-blower-fan-motor-a-detailed
Check out the images (below). Let us know if you need anything else.
Nov 4, 2024 at 12:50 AM
PORK CHOP
  • 5 POSTS
Thanks.
Nov 4, 2024 at 1:14 AM
  • 55,658 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Nov 4, 2024 at 2:23 AM
