Blower motor will not turn off
48,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
  • 6 POSTS
With AC on blower motor runs on number 12 at any position on switch. I have replaced the resistor pack it is digital same result.
Jul 14, 2018 at 1:51 AM
  • 55,732 POSTS
Hello.
It sounds like the HVAC controller is having a problem, but just to be sure can you confirm the part you replaced is the same in the diagrams below? Also, I have included the blower fan wiring so you can see how the system works.
Check out the diagrams (below). Please let us know.
Cheers, Ken
Jul 16, 2018 at 4:37 AM
  • 6 POSTS
That is the part that I replaced with no result.
Jul 16, 2018 at 6:23 AM
  • 6 POSTS
How is the blower fan relay mark and what is its location?
Jul 17, 2018 at 12:56 AM
  • 6 POSTS
Thank you for your reply Ken, the schematic swear helpful still need the location of the blower fan relay.
Jul 17, 2018 at 1:30 AM
  • 55,732 POSTS
There is no relay just the power resistor and the controller. Can you see if the red and black wire has power to power resistor? Also check the ground (black) wire.
Here are are two guides that should help:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
and
Use can use a test tight as well.
Cheers, Ken
Jul 17, 2018 at 4:10 AM
  • 6 POSTS
Hi Ken, yes the red wire has 12 volts and the black wire ohms out to ground.
Jul 17, 2018 at 5:08 AM
  • 55,732 POSTS
If the blower motor runs and you already replaced the power resistor it only leaves the control head. Here is a diagram to help you remove it I would try a used one but you may need to get it initialized.
Is there any wiring damage that you can see? Has the car been wet inside?
Cheers, Ken
Jul 18, 2018 at 2:55 AM
  • 6 POSTS
Hi Ken, no wire damage and has not been wet I will try a used control head. Thank you for your help I will let you know how it turns out.
Jul 18, 2018 at 4:06 AM
  • 55,732 POSTS
Cheers, Ken
Jul 19, 2018 at 3:04 AM
