I have replaced the blower motor and it is running fine on all speeds. The air overeat is minimal through all of the vents. As I select the different vents the air does not blow out any stronger even if the fan is turned to a higher level. I have checked all the fuses and the external cabin filter and they all seem fine. Thanks in advance
Nov 1, 2014 at 6:51 AM
