Blower motor resistor not working as should
14,500 MILES
TEONDRAH24
The temperature knob remains on high all the time.
Aug 24, 2019 at 6:17 AM
Good afternoon.
Do you mean the blower motor remains on high no matter what setting is selected?
Do you have manual or automatic climate control?
Aug 24, 2019 at 6:35 AM
TEONDRAH24
It’s manual.
Aug 24, 2019 at 7:25 AM
And the rest of the answer? I asked about the fan speed?
Aug 24, 2019 at 7:53 AM
Okay, this may be a bad blower resistor and it may be shorted to power. I attached a wiring diagram for you as well as the procedure for replacing the resistor.
The part is called the amplifier and is located by the blower under the dash on the left side. I attached a picture of the location for you to view.
If this is bad, it will provide power to the blower when it does not need it. That is why the blower is always on.
May 27, 2021 at 5:30 AM
