Blower motor resistor
160,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
CASMIHOK
  • 211 POSTS
I replaced my blower motor resistor with a Dorman 973-025 in August. It stopped working last night. Meaning, I got in my truck to drive last night and the feet vent was on 3. No air coming out, I put it on 4 and it worked. I was like what the hell lmao, I just replaced that. Do you think it's a bad blower motor? Is there anything I can do to try and get it to work?
Also, not sure if any of this is relevant. I had it on full heat last night, because it was chilly. It was blowing cold air for about 15-20 minutes before it got warm. Also, about 20 minutes into the drive, 1, 2, and 3 setting started blowing air very very lightly. It was not proper, as it was very clear it wasn't nearly hard enough to be right pressure of air. 1,2, and 3 were blowing the same speed very lightly warm air, and the main reason I even realized it started was the heat on my feet suddenly. So, is this relevant? I don't know
Let me know what y'all think
I got a refund on it because I told Amazon it was defective, I will buy a new one if I have to but if anybody could give me any tips or any other possible reasons I would greatly appreciate it. Thank you guys,
hope you have a great day
Cas
Sep 18, 2019 at 11:36 PM
Good morning,
90% of the time, the reason blower resistors fail is due to high current draw from the blower motor. No one takes the time to do a current draw test on the blower motors when these fail.
I would replace both the resistor and the blower motor. I always did that when there was an issue with the resistor.
Sep 18, 2019 at 11:51 PM
CASMIHOK
  • 211 POSTS
GM replace resistor and blower motor? I thought the thing was called a blower motor resistor? This is what I replaced https://www.amazon.com/Dorman-Techoice-973025-Auto-Part/dp/B0049E74H0
What do I need to do?
Sep 18, 2019 at 11:56 PM
Yes, the blower motor and the blower motor resistor at the same time.
Sep 19, 2019 at 12:15 AM
CASMIHOK
  • 211 POSTS
So, what are you saying? I bought this blower motor resistor in August, replaced my old one, and had working air. Is my new one now broken? Or do I just also have to replace my blower motor? Thank you
Sep 19, 2019 at 12:54 AM
From your description, the new one has failed again. It is solid-state.
This time replace the resistor and blower motor.
Sep 19, 2019 at 1:22 AM
CASMIHOK
  • 211 POSTS
Okay thank you. As far as how dire this repair is, can I just use the 4 setting, and not worry about it?
Sep 19, 2019 at 2:04 AM
Yes, but they all will fail at some point.
Sep 19, 2019 at 2:05 AM
CASMIHOK
  • 211 POSTS
Okay, but other than non functioning air, does it damage anything or that's as bad as it gets? I don't really have a lot of time or money and I'm fine with cracking the windows and bundling up, but want to make sure I am not making anything worse.
Sep 19, 2019 at 2:10 AM
Got it. As I stated, it will get worse over time and you will lose all the speeds. You will not do any more damage except you will be hot or cold depending on your location.
Sep 19, 2019 at 2:13 AM
CASMIHOK
  • 211 POSTS
I understand, just wanted to make sure that was the extent of it. I appreciate it, Im working on my credit and hopefully be in a newer car sooner than later. I appreciate your guys help.
Sep 19, 2019 at 2:27 AM
You are welcome.
Always glad to help.
Sep 19, 2019 at 2:32 AM
