Blower motor or blower motor resistor issues
190,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
EPICKET2
Replaced blower motor resistor, while doing so the hot and ground wires accidentally touched. The fuse to the blower motor blew, so I replaced it and swapped out the new blower motor resistor. Plugged everything back up and the blower will not turn on. Is it possible I damaged the blower motor fan? Or what else should i check? I checked all of the fuses and they are all good. Thanks in advance!! :-)
Jun 1, 2019 at 5:09 AM
  • 110,251 POSTS
Welcome to 2CarPros.
At this point, if you know the fuse is good, we have to determine where the power is lost. I have provided a diagnostic flow chart below in the pictures. I had to break it into several pictures so you could read everything.
To test the system, you will need to use a test light and a volt meter or multi meter. Here are links to help you with using them:
Also, confirm there is power to the fuse you replaced.
_____________________________
One last thought. Check relay 45 in the under hood fuse/relay box. You can either switch it with another relay with the same part number, or test it. Here is a link that explains how to test a relay. Picture 5 shows the relay I'm referring to.
Let me know what you find or if you have other questions. I hope this is helpful.
Jun 1, 2019 at 1:37 PM
