Blower motor not working?
133,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
BEYOUNG304
The blower motor stopped working suddenly. I’ve changed the fuses, relays, blower motor itself and the resistors and still haven’t corrected the problem. I took it to the mechanic, and they said it had to be the climate control, so I replaced it and still did not correct the issue.
Nov 4, 2022 at 7:43 AM
  • 110,248 POSTS
It sounds like you've replaced everything. When you say resister, are you referring to the fan control amplifier at the lower right side of the dash?
If so, then we need to check for either a power loss or a ground-related issue. The fan motor gets power directly and then it routes it through the amplifier which signals voltage to the controller.
Before I can dig into the schematics, I need to know if the vehicle has automatic climate control or manual control.
Nov 4, 2022 at 2:14 PM
