Blower motor not working the connector to the motor is melted
2002 ACURA TL
167,700 MILES
BPEZ
The connector to the motor is melted. Is there a replacement connector p/n?
Jul 5, 2019 at 12:02 AM
Hi BPEZ,
I am not finding a replacement connector so I think your best bet other than buying the entire harness is to go to a junk yard and finding the harness and asking if you can cut the connector off it it or just purchase that harness which will be much cheaper and then cut the connector off. Then keep the harness for future use if you need any other connectors or wiring. Donor harnesses are always a good thing to have around.
Let me know if you need more information. Thanks
Apr 26, 2021 at 5:02 AM
