Would like to know where the blower motor control module/resistor
is located ?
Aug 1, 2020 at 10:34 AM
✓Experienced Mechanic
They are both under the dash. I attached a pic below that shows their locations.
What is happening? Is the blower motor not working at all?
Image (Click to enlarge)
Aug 1, 2020 at 4:32 PM
JOHNKAY870
MEMBER
I replaced a bad blower motor and a close by door blend actuator. I heard the door actuator close and the fan motor was running just fine until day 2, when the blower motor just stopped. I checked all the fuses and replaced 1 relay, (weird reading on test).
I have power to the climate control area but no fan. Any thoughts on my issue?
Aug 1, 2020 at 11:17 PM
Have you checked for power at the fan motor or the resister? One may have failed again.
