Blower motor cuts in and out no matter what fan speed it is on
2004 DODGE DAKOTA
190,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
JOSHMINK26
Blower motor quits working for some reason and I can hit it and it will work again and sometimes it will rev up and down.
Jan 27, 2022 at 12:49 PM
SQM
  • 6,383 POSTS
Sounds like this could be a connection issue or internal loose or worn components for the blower motor or the resistor.
A good first step would be to access the blower motor and make sure the wiring harness is secured.
Look for any corrosion or pushed out or burn pins.
Over time due to a loose connection, you will have burnt pins.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Please let me know what you find or if you have any questions.
Jan 27, 2022 at 1:19 PM
JOSHMINK26
Okay, thank you. I will check it in the morning. The blower sounds good and works at every speed. It will come on soon as I start truck and sometimes it will work fine and other days it will just cut in and out and rev up and down. I can smack it when it cuts off and it will come right on and work.
Jan 27, 2022 at 1:42 PM
SQM
  • 6,383 POSTS
The symptoms that you have sound like a loose connection somewhere.
Let me know what you find out.
Jan 27, 2022 at 1:44 PM
