Blower motor
120,000 MILES • V8 • 2WD • AUTOMATIC
ROGER MCCUEAN
I replaced blower motor it is on high speed all the time.
Oct 31, 2019 at 7:57 AM
STEVE W.
  • 15,413 POSTS
Welcome to 2CarPros. Was it replaced because of the same problem or just because the blower stopped? The front blowers don't use a blower motor resistor to control the speed. they use a signal from the HVAC programmer that tells the module on the blower motor what speed you select. The rear blower does use a resistor. Which one did you replace?
Oct 31, 2019 at 8:30 AM
