Blower motor will not turn off
178,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
HAROLD74
My blower motor will not shut off even when I shut my car off and take the key out. Had to go under hood to take 30 Amp fuse out to shut it off. People said it is my blower motor relay, if so, where is my blower motor relay located at? Please help me.
Jun 12, 2018 at 12:55 PM
JIS001
  • 3,412 POSTS
The blower motor relay will be next to the blower fan under the passenger side panel. You should also inspect the harness. If it is burnt then replace the connector and wires as well.
Jun 12, 2018 at 5:33 PM
