Blower motor not working
140,000 MILES • 2WD • AUTOMATIC
ASHLEY HALE
My A/C and heat will not blow out.
Mar 8, 2021 at 10:34 AM
Good morning,
I attached a wiring diagram for you to view. Check the 2 fuses I circled.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
The resistor is the most common failure for this. I attached the procedure for you below.
REMOVAL
1.Remove the instrument lower finisher. See: Dashboard / Instrument Panel > Removal and Replacement > Removal And Installation.
2.Remove the front foot duct (LH).
3.Remove the accelerator pedal.
4.Disconnect the fan control amplifier connector (B).
5.Remove the two screws (A) from the fan control amplifier (1)
and then remove the fan control amplifier (1).
Mar 8, 2021 at 8:27 PM
