Blower fan does not work properly
129,000 MILES • 3.5L • 6 CYL • 2WD • MANUAL
SUNSETLAKE
Blower motor will not work right. It would run but not like it should. On high it runs like it is on low so I replaced the resister and now it will not work at all.
Oct 4, 2018 at 5:06 AM
  • 110,251 POSTS
If the motor was turning slower than it should be, it may be bad. Have you checked to see if there is power to the blower motor since you replaced the resister? Also, have you confirmed the motor has a good ground and nothing is blocking the fan?
_____________________________________
Listed below is a link for diagnosing blower motor issues. If you page down, it discusses checking the circuit and the motor. Additionally, I have included links which show how to use a volt meter, test light, and how to test wiring.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Oct 6, 2018 at 1:16 PM
