blower fan not working
100,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
JJAYMECH
  • 14 POSTS
Car has CJ2 climate control with the programmer sending a variable voltage to the blower control module. The module transistor varies the voltage to the blower motor. I tested motor with 12 volts direct ... OK. The module receives 12 volts power and ground ... OK. Output wire from module to motor ... OK.
But, with module disconnected, I try to check the variable voltage coming from programmer. It reads 8.2 volts at every fan speed with ignition in "run" position.
Jun 22, 2021 at 4:01 PM
Good morning,
This sounds like the blower motor control module has failed internally and not changing voltage the way it should.
I would verify power to the module. If you have battery power to the module then most likely the blower module is the issue.
I attached the diagram of the system for you below for you to view. I also attached the procedure for you for the replacement.
Jun 22, 2021 at 7:49 PM
JJAYMECH
  • 14 POSTS
The diagrams are quite different from the factory manual drawings. The module has 4 terminals: hot power, ground, input signal, and output voltage. I have checked those things. My concern is the input signal from the HVAC programmer. With the module disconnected, the signal reads 8.2 volts instead of a variable voltage as the speed button is changed. If that were true it shows the programmer is at fault. But all the door functions work normally, except blower fan. I guess my next step is to back probe the input signal when the module is connected. The symptoms indicate a bad module, but only if the input signal checks okay. My module is ACDelco 15-8684.
Jun 22, 2021 at 11:46 PM
Can I have your complete VIN number for the car?
Jun 23, 2021 at 12:45 AM
The 8.2 might be good. It or the control may just be calling for a slower speed than full blast. I attached the correct diagram for you.
Check the fuse I circled for power on both sides.
Jun 23, 2021 at 2:07 AM
JJAYMECH
  • 14 POSTS
The blower feedback fuse 11 in the relay center checks good. The factory flow chart says the input signal voltage should be between 6-8 volts, definitely not less than 6 volts. So that checks okay. I am 99% certain it is the blower control module. A new module is $200.00 plus shipping to Canada. Since I am also an Electronics Tech, I am going to replace Power Transistor.
Jun 23, 2021 at 3:05 AM
JJAYMECH
  • 14 POSTS
When the module is disconnected, I believe the input signal just shows a standby voltage since there is no blower feedback signal. Getting closer!
Jun 23, 2021 at 3:07 AM
That is correct.
I attached the part for you from Rock Auto. It has a power transistor attached to it. It is only $110.00. Call them and see what the shipping is to your location.
Jun 23, 2021 at 5:09 AM
JJAYMECH
  • 14 POSTS
I ordered a new module from RockAuto, after soldering in a new power transistor did not work. Now it works great. During my initial testing I spun the squirrel cage blower by hand to confirm that it was not tight or seized. I also applies a direct 12 volts to it. All was good.
Jul 1, 2021 at 2:26 PM
Glad to hear it worked for you.
Always glad to help.
Jul 1, 2021 at 9:48 PM
