Blower motor control switch speed on dash for heat and air?
118,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ADERBY550
And I turn on the air or the heater. The control switch does not work on 1,2,3 clicks) lower settings). I have to turn it all the way up to as far as it can go, which would be 5. It’s not numbered it just has a color mark like starting small and going to the largest -I have to turn it up to max (5) or it won’t blow sometimes i want it on 4 if it’s getting too hot or too cold in the car and if I turn it just right, which takes time I can get it to stay there to be honest it doesn’t make a lot of a difference but a small difference if I try to turn it to medium speed(3) I will get no blowing out of the vents. Why doesn’t it work in the lower blowing modes and only the higher or the highest blowing mode lately, I’ve been having to put a matchbook or toothpick or something underneath it to hold it up a bit and it does not seem loose at all, and I’ve just been hearing a flapping sound on the passenger side under the windshield Behind the dash like where the wheel when I start the car and it stops after a min or so. . It recently went to a Mechanic that the tow company recommended, the throttle body engine light came on and I think it went into limp mode it had been jerking for a few months and poor gas mileage. I thought it was the spark plugs. I’m a single mom who has cancer and don’t know anybody to fix it so I was just wondering if you guys could give me your best guess on how much it will cost and if it will be fixable on what it is.
Jan 17, 2025 at 10:59 PM
  • 55,604 POSTS
I am sorry to hear about your troubles, I will try to help you the best I can. Please make a new question for the limp mode issue, we only handle one problem per thread, please post your new question here, you must be logged in.
As far as the blower motor problem is concerned it sounds like the blower motor speed control is not working. The high-speed fan setting bypasses this part which works on high. Here is the location of the speed control so you can see what needs to be done if you want to fix it yourself. The part should be about $40.00 and the labor about $80.00. Check out the images (below). Please let us know what happens.
Jan 18, 2025 at 4:54 AM
