Blinking PNRD lights on dash
150,000 MILES
GARRETT DILLON
So my girlfriends car is having this problem where when she puts it in drive she has to put the pedal all the way to the floor, and it takes forever for it to get up to speed. She says the reverse light and the drive light blink when she puts it into those gears. please help.
Jan 29, 2021 at 2:37 AM
STEVE W.
  • 15,388 POSTS
The description sounds like the transmission is in limp mode do to an internal issue. That would be the reason for the blinking lights in those gears. The first thing to do would be to use a scan tool to pull any stored codes from the transmission and see what those show. It could be something like a bad solenoid pack or internal parts damage but the codes would be the first place to start. Unfortunately many of the places that were doing free scans have either stopped or restricted their activities and most wouldn't scan the transmission controls anyway. So you are left with buying a scan tool for a few hundred dollars or having a shop scan it and then getting a few opinions on what the issue is. This transmission doesn't have a dipstick so even checking the fluid color and condition isn't an easy thing to do without having a lift to get under it to access the fill/drain plug.
There was a recall on these for acceleration lag (NHTSA # 14V212000) in which they reprogrammed the transmission control module, but it didn't involve any of the lights flashing.
Jan 29, 2021 at 3:19 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The first thing you should do is to perform a CAN scan to check all the systems on your car mostly including the transmission. Here is a tutorial showing what is involved for a CAN scan code check:
After performing this get back to us with the code information and then we can properly diagnose the issue. Hope this helps and thanks again for using 2CarPros.
Jan 29, 2021 at 9:42 AM
