Blinking D, speedometer not working
130,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
ARMYSURF844
Hey folks.Today I noticed the D was blinking. Along with that, the speedometer isn’t working. car won’t shift out of first gear and it wouldn’t allow me to put the car in park. Can anybody help with what’s going on??
Jan 2, 2020 at 12:17 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
First thing we need to know is if there are any trouble codes related to your issue, if you haven't checked for trouble codes yet.
here is a link to our tutorial on how to retrieve the codes: https://www.2carpros.com/articles/checking-a-service-engine-soon-or-check-engine-light-on-or-flashing
The flashing D actually is the equivalent to the check engine light but for the transmission instead however the instructions for the check engine light will work similarly to the check engine light. I have a few suspects that could cause the issue you are experiencing. the first one is the range switch which tells the computer which gear you have selected, if the computer doesn't know you have put the transmission into drive then it won't tell it to shift. Another likely suspect could be one of the speed sensors in the transmission, there are two of them and if either are faulty this can cause shifting issues also. There are also shift solenoids that can cause a no shift condition so the main thing that would help us is to find out what codes are in the computer.
Please let us know what codes you find and thank you for using 2CarPros!
Jan 2, 2020 at 8:10 PM
