Blinkers will not work
80,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DUCKDLB
The blinkers will not work, the flashers work. we replaced the switch and it still do not work.
Mar 14, 2018 at 9:31 AM
Good morning.
The flasher is a combo flasher for both the turn signals as well as the 4 ways.
first, be sure all bulbs work. if they all work the flasher module is the failure.
REMOVAL PROCEDURE
1. Remove the left IP closeout/insulator panel.
2. Remove the turn signal/hazard warning flasher (2) from the IP carrier.
3. Pull down and disconnect the electrical connector (1) from the turn signal/hazard warning flasher (2).
INSTALLATION PROCEDURE
1. Connect the electrical connector (1) the turn signal/hazard warning flasher (2).
2. Connect the turn signal/hazard warning flasher (2) to the IP carrier.
3. Install the left IP closeout/insulator panel.
Mar 14, 2018 at 9:53 PM
DUCKDLB
Thanks for the help. I will let you know if it works.
Mar 14, 2018 at 10:44 PM
You are welcome. we will be here.
Mar 14, 2018 at 10:45 PM
