Blinkers not working properly
202,700 MILES • 3.5L • 6 CYL
JUSTINLEE89
Okay, when I turn my blinkers on they will work for one or two seconds then stop. I've checked the bulbs and check fuses. I found a little black I think it is the flasher relay under my dash next to my firewall. well I'll like get a screwdriver something out tap that and they'll start working again, but they'll stop right afterwards.
May 31, 2019 at 6:15 PM
  • 110,248 POSTS
Welcome to 2CarPros.
The turn signal flasher, also referred to as the combo-flasher, is mounted to an in-line bracket which is located to the right of the Junction Block (driver's side). The flasher can be removed by pulling in a rearward direction. The left under panel silencer duct must be removed to access the flasher. The combo-flasher is black in color for ease of identification. If that is what you are hitting to make it work, replace the flasher.
Let me know if I can help in any way.
Jun 1, 2019 at 12:13 PM
