Blendoor actuator on passenger side
200,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
GSANDERS
  • 5 POSTS
Do you know part number for that part?
Aug 19, 2016 at 12:42 PM
SATURNTECH9
  • 30,869 POSTS
I do not see a left and right blend door actuator listed. Is this a 1500 Sierra? The part number will be right on the part I use those numbers to help find the correct aftermarket parts as well. The aftermarket parts will say it replaces a certain factory part number.
Aug 19, 2016 at 1:03 PM
GSANDERS
  • 5 POSTS
Yes, but at advance the description says driver side.
Aug 19, 2016 at 1:42 PM
SATURNTECH9
  • 30,869 POSTS
That is what I show on rock auto dot com for descriptions.Honestly your best bet would be to get the part number on the actuator itself. That is what I would do from seeing the descriptions with lack of listing a passenger side one .
Aug 19, 2016 at 1:56 PM
GSANDERS
  • 5 POSTS
Is the part called lower blend door actuator or main blend door actuator?
Aug 20, 2016 at 3:35 AM
SATURNTECH9
  • 30,869 POSTS
On those trucks usually the lower one in the middle is the drivers side blend door actuator.I do not see how a main blend door actuator could ever be referred to the passenger side one. I cannot read the part number on that label can you read it to me?
Aug 20, 2016 at 6:43 AM
GSANDERS
  • 5 POSTS
It is worn off, I cannot either.
Aug 20, 2016 at 7:26 AM
GSANDERS
  • 5 POSTS
I got the part. thanks for your assistance.
Aug 20, 2016 at 7:28 AM
SATURNTECH9
  • 30,869 POSTS
You are welcome. glad you found it.
Aug 20, 2016 at 7:40 AM
