Do you have to take the whole dash off to replace the HVAC actuator?
Jan 3, 2018 at 2:41 AM
✓Experienced Mechanic
Good afternoon.
Which actuator? there are three different ones. Which function is not working?
Jan 3, 2018 at 4:37 AM
DEW.HICKIE
MEMBER
The HVAC actuator/blend door.
Jan 3, 2018 at 4:54 AM
DEW.HICKIE
MEMBER
Heat.
Jan 3, 2018 at 4:55 AM
Okay, sorry, but the answer is yes. the dash has to be removed to gain access to the top of the heater case. I attached a picture for you to view.
Image (Click to enlarge)
Jan 3, 2018 at 4:58 AM
Has the actuator been confirmed as the failure?
Jan 3, 2018 at 5:01 AM
DEW.HICKIE
MEMBER
I have replaced the radiator, thermostat and checked the heater core. I get about thirty seconds of heat then it goes to cool air.
Jan 3, 2018 at 6:07 AM
Okay, if you get some and it goes to none I doubt it is the actuator.
move the heat/cool control back and forth and see if you hear the mode door moving.
Are both heater hoses hot to the touch under the hood? It sounds like you have a clogged heater core.
