Blender actuator location
118,000 MILES • 5.6L • V8 • 2WD • AUTOMATIC
MICHAEL LUTZ
Where is the blender actuator located?
Jan 3, 2019 at 12:09 PM
  • 110,248 POSTS
It is located under the dash on the AC/heater box. There are two of them, one for each side. First, here is a link that shows in general how one is replaced:
Here are the directions specific to your vehicle for replacement. Also, the attached pictures correlate with these directions,.
______________________
2008 Nissan-Datsun Truck Titan 2WD V8-5.6L (VK56DE) Flex Fuel
Air Mix Door Motor
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Removal and Replacement Air Mix Door Motor
AIR MIX DOOR MOTOR
AIR MIX DOOR MOTOR
Removal and Installation
Exploded View VTL-20
See Pic 2
AIR MIX DOOR MOTOR (DRIVER)
Removal
1. Remove the heater and cooling unit assembly.
2. Remove the steering member from the heater and cooling unit assembly.
3. Disconnect the air mix door motor electrical connector.
4. Remove the three screws and remove the air mix door motor.
Installation
Installation is in the reverse order of removal.
AIR MIX DOOR MOTOR (PASSENGER)
Removal
1. Remove the center console lower cover LH.
2. Disconnect the air mix door motor electrical connector.
3. Remove the three screws and remove the air mix door motor.
Installation
________________
Jan 3, 2019 at 1:01 PM
STEVE W.
  • 15,403 POSTS
Welcome to 2CarPros.
Might I assume you are looking for the location of the heater air mix door actuator as I don't recall a blender option on a Titan? There are two on that trucks HVAC system. One which is used to control the passengers side temperature is located on the bottom of the HVAC case and is visible from under the dash over the transmission tunnel. The other one that controls the drivers side temperature is located on the top front of the HVAC case and requires that the steering column, dash assembly and the heater case be removed to get access to it for service. To do that you also need to drain the coolant, and recover the AC charge.
In the image the passenger side unit is number 5 and the drivers side is number 3. Note that image is reversed from how it would set if you are inside the truck.
