Heater will not blow hot air
117,000 MILES • V8 • 2WD • AUTOMATIC
HINSON
Sometimes you can hear a door pop open then it will work but that's not a lot.
Dec 3, 2019 at 6:20 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, it sounds like you are having trouble with the blend door actuators.They are small electric motors that open/close a flap to direct air through the specific vents.Here is a tutorial showing how to replace:
I've attached step-by-step instructions below for replacement and also their location.There is a driver and passenger side actuator.Hope this helps and thanks for using 2CarPros.
Apr 23, 2021 at 3:54 AM
HINSON
There's not a clicking sound in the dash when the trucks running or I turn any of the controls. The actuators look like they turn like they are supposed to. How do you recalibrate the system?
HINSON
How to get air out of vacuum lines of heater by jacking up?
  • 55,748 POSTS
Yes, jacking the front or rear the the truck up and can force the air pocket out of the heater core. here are two guides to help:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
and
https://www.2carpros.com/articles/car-heater-not-working
