Cheers
Images (Click to enlarge)
Nov 14, 2016 at 7:27 AM
BINGHAMTON
MEMBER
1 POST
My climate control blows whatever air outside inside without any change, hot out hot in, cold out, cold in, moderate out, moderate in.
Jul 15, 2018 at 4:41 AM
(Merged)
JDL
✓Experienced Mechanic
Are you saying the temperature control on HVAC does not work? Some makes and models, the HVAC has a diagnostic feature that can enter diagnostics. I will have to double check for your vehicle.
(Merged)
JDL
You can enter HVAC diagnostics. Press the off and defrost buttons at the same time, then press the auto button within two seconds.
The codes, if any should show up on the HVAC display. Let us know about the codes.
(Merged)
GGMYERSJR
MEMBER
1 POST
If I am correct, there are more than 1 door. Is there a way to tell which one is faulty
04 LS, V8
May 13, 2019 at 2:20 AM
Yes can you tell me which mode is not working? temperature or vent direction?
