Blend door actuator not getting any power
200,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
SURGEIMPULSE
  • 67 POSTS
In the beginning I heard clicking coming from behind the dash, accompanied with the inability to change temperature. After taking out the glove box, I noticed the source was from the blend door actuator, which went bad. I went to rockauto.com and got a replacement, and quickly replaced it. It may have been foolish not to disconnect the battery, but I figured that it would not be that big of a job. After plugging it in, I found out that no power goes to the new actuator. Any advice that I could get?
Oct 24, 2018 at 3:14 AM
Good afternoon
The battery does not have to be removed for this repair. they key should be off.
I will attach a wiring diagram for you to view. make sure there is power to the blend door actuator when you command cool or heat. make sure the connector is not damaged as well. inspect the pins for any damages or burned pins.
Oct 24, 2018 at 7:29 AM
SURGEIMPULSE
  • 67 POSTS
This diagram is for inside the dash, correct? The air also only goes through defrost and and floor, no matter what I set the climate control to. I checked the wires connected to the BDA, and surrounding areas, including fuses. No issues.
Oct 24, 2018 at 11:12 PM
If you verified all voltages to the actuators, then you either have a bad actuator or the doors they are moving are seized.
Oct 25, 2018 at 12:58 AM
SURGEIMPULSE
  • 67 POSTS
Used a ratchet to see if the doors have any move, they work perfectly. New actuator I ordered must have been damaged on shipping or something because the replacement works great! Thank you.
Oct 25, 2018 at 1:23 AM
Your welcome
Always glad to help.
Oct 25, 2018 at 2:39 AM
BRYANLANNING
Hey guys,
I've noticed this real pungent smell in my car lately. Its like a sweet chemical smell. Its been getting progressively worse. My coolant was low the other day so I filled it up and the next day it was low again. The vents have been spraying this smell I'm smelling constantly and fogging up my windows like crazy! My windshield actually turned green while driving! The fumes are getting crazy hard to handle and I can't drive it because it gets hot and the windows fog up.
Could this be my heater core leaking? Are the problems related? How much would getting something like this fixed cost? I'm a poor student who needs to get this fix ASAP.
Nov 11, 2019 at 9:39 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
YEah you have a leaking heater core.
IF you can live without heat, you can by pass the heater core.
Very expensive job. Book time is about 9 hours.
CASSIEDENAPOLI
  • 9 POSTS
Heater problem
1994 Ford Thunderbird V8 Automatic ? miles
if i turn the heater on it doesnt come on right away almost like it sticks what would be wrong
2CARPRO JACK
  • 11,533 POSTS
You mean the fan does blow right away? could be the fan motor.Does it ever not work? if so it is located under the dash pass side, remove plastic shield and tap on it to see if it comes to life
CASSIEDENAPOLI
  • 9 POSTS
if you turn it on it will blow out a little bit but then it will automatically just start coming on all the way one time we went over a big bump and it came on full blast
CASSIEDENAPOLI
  • 9 POSTS
ok i turn the heater on high it comes on a little futher down the road it will just start worker full blast almost like it has a relay problem or something not sure or maybe a hose could be loose or something
2CARPRO JACK
  • 11,533 POSTS
Sometimes when themotors are going out they get sticky like that. Remove the shield under the dash on the passenger side and find the motor.When it doesnt turn on, tap the bottom of it with something and see if it comes on.We will start with the usual problems and go from there
CASSIEDENAPOLI
  • 9 POSTS
Thank you so much for your quick reply i will let you know if i have anymore problems or if that resolves the issue. if not do i need a new blower motor and does it have a relay?
2CARPRO JACK
  • 11,533 POSTS
I dont see any relays in the system. Most likely will be the blower motor, but check the resistor too, it is located next to the blower motor, follow the wires back to it.The resistor controls fan speed, it may be shorted too
CASSIEDENAPOLI
  • 9 POSTS
would the resistor be the same thing as a pwm blower control
2CARPRO JACK
  • 11,533 POSTS
Is this an automatic system or manual? The resistor is called that, a resistor or fan speed controller if it is solid state
CASSIEDENAPOLI
  • 9 POSTS
it is a automatic so what is a blower control then
CASSIEDENAPOLI
  • 9 POSTS
here is a pic of it
https://images.2carpros.com/forum/automotive_pictures/319064_002_1.jpg
2CARPRO JACK
  • 11,533 POSTS
Blower motor speed controller
try motor first
CASSIEDENAPOLI
  • 9 POSTS
i have another question while driving i hear a clinging noise in my front tires any suggestions?
