I am looking for a way to put on the actuator, but i cannot find the mounting bracket.
Nov 2, 2017 at 2:27 AM
WRENCHTECH
✓Experienced Mechanic
There is no bracket. There will be three small elevated plastic areas with threaded holes.
Image (Click to enlarge)
Apr 30, 2021 at 6:41 AM
ALISHA PURCELLA
MEMBER
The holes so not line up but there is a 14 difference between the actuator and the blower box. The Chevrolet place says the mounting bracket is discontinued.
WRENCHTECH
Then I guess the only option you have left is to find one in a U-pull-it junkyard. I am sure you will have to remove it yourself because the yard will not be bothered with something like that.
