Blend door actuator location and removal instructions needed
210,000 MILES • 5.4L • V8
E22
No heat and clicking noise in dash.
Dec 7, 2020 at 10:02 AM
  • 110,248 POSTS
It should be located under the dash on the right side of the heater box. Here are the directions:
_____________________
2014 Ford Truck E 150 V8-5.4L
Temperature Blend Door Actuator
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Removal and Replacement Temperature Blend Door Actuator
TEMPERATURE BLEND DOOR ACTUATOR
Removal and Installation
1. Remove the temperature blend door actuator.
1. Disconnect the temperature blend door actuator electrical connector.
2. Remove the 4 screws.
3. Remove the temperature blend door actuator.
pic 1
2. To install, reverse the removal procedure.
________________________
I realize the directions are vague. Here is a link you may find helpful for replacement:
Dec 7, 2020 at 11:24 AM
