Where is the Blend Door Actuator located?
20,000 MILES
DLEE87250
  • 7 POSTS
What is the location of the blend door actuator?
Jul 24, 2022 at 9:01 AM
  • 110,251 POSTS
The actuator is under the dash on the right side of the vehicle, mounted to the HVAC box. For replacement, I attached the directions specific to your vehicle below. Additionally, here is a link you may find helpful. It explains how in general one is replaced.
Jul 24, 2022 at 3:34 PM
DLEE87250
  • 7 POSTS
Thank you for the reply. Is the location of the components the same for the 2016 Express Cutaway?
Jul 24, 2022 at 3:41 PM
  • 110,251 POSTS
It should be the same. If you run into trouble, let me know.
Jul 24, 2022 at 3:44 PM
DLEE87250
  • 7 POSTS
Do you have a bigger diagram that shows approximate location of the actuator?
Jul 26, 2022 at 8:16 AM
  • 110,251 POSTS
That's the only pic I have. I didn't mention it in the post above. Number 1 in the pic is the actuator. It will be on the side of the HVAC box. You should be able to access it from the passenger side under the dash. Note that I say passenger side, but it is close to the center.
Jul 26, 2022 at 1:07 PM
DLEE87250
  • 7 POSTS
I opened up the dash and I am seeing a steel plate that was welded. It seems like I can't take it out for me to access the HVAC box.
Jul 26, 2022 at 1:54 PM
DLEE87250
  • 7 POSTS
Here is the picture.
Jul 27, 2022 at 2:19 AM
  • 110,251 POSTS
I believe you have to remove the knee bolster bracket. Take a look at the pic below. I copied your pic and circled the part I'm referring to. Once that is out of the way, you should be able to access the box.
Additionally, I attached the extremely vague directions below. That bracket is held in by 4 screws. Take a look and let me know if it helps. Once the screws are removed, gently pull it away from the panel.
Do me a favor. Before you go to this trouble, confirm it will allow access. This is what is indicated in the manual. If it doesn't, let me know.
Jul 27, 2022 at 12:58 PM
DLEE87250
  • 7 POSTS
Thank you! Worked like a charm. I replaced the actuator, and the A/C is good as before. I truly appreciate your help.
Jul 27, 2022 at 1:55 PM
  • 110,251 POSTS
You are very welcome. I'm glad to know it's fixed, so thank you for the update.
Take care of yourself and please feel free to come back anytime in the future if you have questions. You are always welcome here.
Jul 27, 2022 at 3:22 PM
