Where is the blend door actuator located?
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
HEATHER51698
I need to know where the location of the blend door actuator is so I can check it. My A/C is only blowing hot heater air.
Mar 15, 2024 at 7:04 AM
  • 110,248 POSTS
The air mix actuator is cable controlled. It is located under the dash approximate center. I attached a pic below. Locate the cable in the pic and manually change the air temperature knob to see if the cable is moving the lever.
Let me know what you find.
joe
See pic below.
Mar 15, 2024 at 12:25 PM
