Where is the blend door actuator located?
2008 KIA SPECTRA
154,000 MILES • 4 CYL • 2WD • AUTOMATIC
4JIMMY2JAM0
Blend door actuator.
Jun 14, 2022 at 6:06 AM
  • 110,241 POSTS
The blend air door actuator is located under the dash approximately center of the dash. It's mounted on the HVAC box. If you look at pic 1 below, it shows its location.
The actuator is held in with four screws. It's a bit difficult to access, but it can be done.
Pic 2 below provides the very basic directions for replacing it. Here is a link you may find more helpful:
Jun 14, 2022 at 2:50 PM
