Blend door actuator removal?
232,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
WNM4RUNNER
Want to replace driver side blend door actuator. I take the two screws out, disconnect wiring harness but, while the actuator seems loose, it will not come out. What am I missing?
Aug 12, 2025 at 5:45 AM
  • 55,691 POSTS
The problem is there are three screws holding the driver side blend door actuator onto the HVAC plenum. One is hidden toward the top-rear, requiring a shallow socket or stubby screwdriver to reach. I hope this helps.
Aug 13, 2025 at 3:55 AM
