Heat only blowing through floor vents
78,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
DGAG
Heat only blows through floor vents. When switch to vents or defrost it stays blowing out floor. Where is the blend door actuator located?
Apr 6, 2018 at 5:11 AM
WRENCHTECH
  • 20,760 POSTS
The blend door actuator is a temperature control. What you are looking for is the mode control actuators. They should be on the left side of the HVAC housing, above the gas pedal.
Apr 6, 2018 at 6:05 AM
